CARVER site! Mobile
  Featured System
Carver audio forum, free Carver manuals, Carver audio information, Carver audio repair, Carver specifications, Carver modification, Carver upgrade, Carver amplifiers, Carver amplifier, Carver amp, Carver home audio, Carver hifiNow Playing
Now Playing: The Flaming Lips, Stardeath and White dwarfs, with Henry Rollins and Peaches "doing "the dark side of the moon""
Welcome Guest! To enable all features please Login or Register.
Notification
Icon
Error
Phono stage
#1 Posted: Friday, June 26, 2009 9:58:11 AM(UTC)
Send to facebookSend to DelisciousSend to StumbleuponDigg thisSend by emailSend to Addthis
Rank: Guest
Groups:
Was thanked: 1 time(s) in 1 post(s)
Hey Fellow audiophiles, new member. new to sunfire that is. Recently aquired a classic tube pre matched with signature 600-2 driving maggies 3.6R's. The gentlemen I purchased them from was a phono guy, I am not(yet). I am am also new to tubes. He had installed the phono board with upgraded tubes. I was wondering since I will be enjoying this almost daily but not using the phono stage. should I disconnect the phono board to extend the life of the tubes? thank you in advance.
Sponsor
RichP714Offline
#2 Posted: Friday, June 26, 2009 10:38:42 AM(UTC)
Medals:
ZeroPointe: Black Pearl device for multiple award; audio tools owner
Rank: Vendor
Groups: Member
Was thanked: 454 time(s) in 337 post(s)
Gave Thanks: 322 times
Welcome rtu........tubes aren't my dept, but hopefully someone who knows will pipe in.
Enjoy!
------http://zeropointe.thecarversite.com----------------------http://carvermk2.com---------------
BillDOffline
#3 Posted: Friday, June 26, 2009 11:37:37 AM(UTC)
BillD
Medals:
Senior: Black Pearl device for multiple award; senior memberModerator: -Mentor: Tirelessly shares their knowledge with others
Samaritan: exemplifies the spirit of Rahu, dispositor of KarmaSite Builder: Black Pearl device for multiple award; major contributor to the Carver site! community.Technician: repair specialist
Cee-Bang!: donated to fund CARVER site! hostingFeatured: systemCarver modified: Carver mk II, or self-modified owner
Bill D modified: audio equipment ownerDigital: specialistDIY: master builder
Music: extensive, varied collectionGreeter: pearl device
Rank: TO-3 Member
Groups: Administration, Search Party, Moderator
Was thanked: 168 time(s) in 139 post(s)
Gave Thanks: 2 times
See my post replying to your other post of the same subject.
It should sound like it isn't there.
There is a difference between hearing and listening...
Making life enjoyable through expensive electronics.
__________________________________________________________________________
Carver: C-4000 & C-1 preamps, PSC-60 preamp/tuner, TX-11a tuner, C-500, M-1.0t, M-400 (2), M-500, M-500-t+, M-500t Mk.II, A-500x, AL-III loudspeakers (2 pr)
Sunfire: Theater Grand III processor, Ultimate Receiver, Cinema Grand Signature 400 ~ seven, True Subwoofer Mk. II, D-10 Subwoofer
BillDOffline
#4 Posted: Friday, June 26, 2009 11:39:29 AM(UTC)
BillD
Medals:
Rank: TO-3 Member
BalokOffline
#5 Posted: Friday, June 26, 2009 12:31:40 PM(UTC)
Balok
Medals:
Senior: Black Pearl device for multiple award; senior memberSite Builder: Black Pearl device for multiple award; major contributor to the Carver site! community.Cee-Bang!: donated to fund CARVER site! hosting
Featured: systemCarver modified: Carver mk II, or self-modified ownerDIY: master builder
Tunesmith: master sleuthJester: -Music: extensive, varied collection
Rank: TO-247L Member
Groups: Member
Was thanked: 47 time(s) in 42 post(s)
Gave Thanks: 23 times
Bill, your accidental "double post" regarding rtu0894's post in TWO areas struck me as funny. Of course, i have been drinking............:dd
"ALL THINGS MUST PASS"
BillDOffline
#6 Posted: Friday, June 26, 2009 2:43:42 PM(UTC)
BillD
Medals:
Rank: TO-3 Member
You mean you thought I didn't do that on purpose?
#7 Posted: Sunday, June 28, 2009 6:01:24 PM(UTC)
Rank: Guest
Groups:
to answer your question, I did try the RIAA reverse phono loop, but I can not give and accurate review just yet because I changed to many things at once. I just started using the SD/A-490t cd player, which has its own tube buffer. Howerver, I happen to be bypassing this as well through the digital out. I've already become acustom to the Musical Fidelity X-series (PSU, DAC, 10, the X-10 of which is an output tube buffer as well). I also agree that I need to take advantage of the phono section with an actual turntable. but at this point I don't own one or know much about them. And due to the fact that my LP collection consists of zero! I fugure I will not be using the phono section for a while. This brings me to the original question: If the phono stage is not going to be used, should I remove it to save tube life. Or do they not wear out runining idle?
OBI56Offline
#8 Posted: Sunday, June 28, 2009 6:17:58 PM(UTC)
Medals:
Senior: Black Pearl device for multiple award; senior memberScribe: expert on statistics and specificationsTurntable: specialist
Rank: TO-220 Member
Groups: Member
Was thanked: 22 time(s) in 16 post(s)
Welcome to the forum rtu0894. AFAIK tubes used in preamps and CDPs are usually stressed very little; so little in fact that they should usually outlive their owner as well as the equipment they are in. Tubes used in power amplifiers are another story entirely, usually lasting anywhere from a few years to a decade or more.
I wouldn't worry about the longevity of the tube life in the phone section as the chassis of the Classic Tube Preamp has plenty of space in it and ventilation is not a problem. On the other hand, removing it won't harm anything as long as you replace the chassis mounting plate with the original one to get your CD input back.
#9 Posted: Sunday, June 28, 2009 7:11:47 PM(UTC)
Rank: Guest
Groups:
Thanks for the tube info.
Rss Feed Atom Feed
Users browsing this topic
Forum Jump
CARVER site! theme by Richard G. Pecoraro
Powered by YAF 1.9.5.5 | YAF © 2003-2011, Yet Another Forum.NET
This page was generated in 0.253 seconds.
Follow Us
follow on Pinterest
Join our facebook group
CARVER site! audio forum on facebook
CARVER site! Toolbar install
Follow Us
follow on Pinterest
copyright© 2008 thecarversite.com All rights reserved
